By "filtering" I assumed low pass filtering...but you made a high pass filter.
And what's the use of the 1mH inductor? And what's the use of the 10k resistors? I assume this all is useless somehow..
And what is connected at the output? An inductance? Causing a resonance in combination with the capacitors? With high resonance voltage?
A lot of unknown things.
Klaus
For an equivalent capacitance/voltage rating, ceramics are going to be much larger and costlier. But will have a much lower ESR. Be aware that capacitance may change greatly as you get above half the rated voltage.
