cupoftea
Advanced Member level 6
We are doing a Buck with Vin=24-32V, VOUT=13V5 AND iOUT = 15A at 450kHz.
When its input connector is suddenly "Hot plugged" with a 32V input supply, the voltage on its 10uF, 50V MLCCs peaks up to
56V for a few microseconds. They are only rated 50V....do you think this will cause premature failure if it happens say ten times a day for
5 years?
(PNG and LTspice attached)
5 years?
