Centre Tapped Inductor- Help Needed
hrkhari
Full Member level 4
Full Member level 4
Hi Guys:
The attached file shows the visualization of a centre tapped spiral inductor. In order to tap the common centre of the inductor to ac gnd, hence to enable differential operation, I need to connect a layer of Metal 5 in VLE as shown in Port 3, I would appreciate if anyone could help out in suggesting the optimum distance d in order to achieve an optimized performance. I also welcome any suggestion of alternative tapping method in ASITIC, itself. Thanks in advance.
Rgds
