neoflash
Advanced Member level 1
Guys,
When the cell phone is in charger mode, the internal circuits are still supplied with the battery or some LDO from the charger line?
For example, the PMU will disconnect the battery and connect another LDO to supply the internal circuits?
Also, another question is that when the battery is in charging mode, what is the voltage waveform appears at its nodes?
Thanks,
Neo
Thanks,
Neo
