yes i want the same kind of info. here in my country it says like "GT road Islamabad"
this info is transmitted at cell broadcast channel (cbc)50
the AT command for this is at+csbs but dnt know the exact parameters or usage of this command plz help me i know this can b done plzz
thnx thnx thnx a lot
it worked wid a lil change
it was
AT+CMGF=1
AT+CNMI=2,0,2,0,0
AT+CSCB=0,"50","0-9"
thnx a lot
it did a large portion of my prj els i had to make a look up table for location names
these are the AT commands that give u the cell info display on ur gsm modem, this involves the name of the BTS that ur modem is connected to, given that service provider transmits that information
first you should check whether your sim900 support this cscb command or not, if it does then it must b having some other parameters, read the AT command version of your sim900 as at commands may differ in diff versions supported by different modules.
find cscb and go through the parameters, it must b due to change of parameters
