yamanoorsai
Newbie level 5
Dear All,
I am trying to implement 0-230V variable voltage control to my high voltage power supply. I am using a ceiling fan regulator to do the same. But I am not able to control the voltage. When I keep the regulator in off position, I am able to keep the power supply to the module switched off. However, when I turn on the knob, the voltage is maintained at 50W, even when I try to vary my knob from 0% to 100%.
I connected my power supply using the following link:
I connected the line of my power supply directly. I connected the neutral end to the regulator and the other end of the regulator to the neutral line. What could be the possible reason that I am not able to control the voltage?
