starrinesss
Junior Member level 1
cadence cdl files
The prolem is finding a way to export CDL netlist contains parameters defined by myself of specified model.
Take resistor for example. By deafult, a resistor in a CDL netlist have a form below:
R1 VDD VSS 1K RP
It means a resistor connect to VDD and VSS has a 1K ohms value and model name is RP.
Now I need 2 additional parameters W and L. The form in the netlist would change to
R1 VDD VSS 1K RP W=10u L=1u
So what should I do if I want the additional parameters be exported automatically by Virtuoso CDL Out (In icfb, use File --> Export --> CDL).
I tried to modify its CDF parameter, in auCDL, but still do not work.Can anyone kindly help me?
I still found it relates with parameter name, for example, if the parameter name is L, it could be exported, if the name is Length, it couldn't be exported. Why?
R1 VDD VSS 1K RP
