grizedale
Advanced Member level 3
Hello,
In an offline SMPS, please can you confirm that conducted common mode noise is ONLY caused by signals which radiate out of the switching stage and return to the neutral wire at a point outside of the mains input connector.?
So, for common mode noise to occur, some signal must actually *radiate* out from the smps.?
...this must be the case, because current ALWAYS travels in loops, and so any noise that doesnt radiate will simply loop back and go back down the neutral wire....and thus NOT produce common mode noise.?
