zahrein
Full Member level 2
For MOS transistor, i have known that the cascode current mirror will put a higher output resistance and therefore it will dicrease the channel length modulation effect.
The formula is : Rd = 1/ λId
I have understood that , when we put the current mirror in cascode it will increase the output resistance (Rd) and therefore it will dicrease the channel length modulation effect(λ). And thererefore we can get a a constant current.
What about BJT,? I know by cascode current mirror , it will increase the output resistance. What is the main factor that increases the output resistance?
Is it the Ic or something else. Thank you.
