eem2am
Banned
smps noise filter
Hello,
I am making an offline LED driver at 20Watts.
It feeds off UK mains 230VAC.
It consisists of two simple SMPS's in cascade:-
First after the mains diode bridge there is a Continuous conduction mode, current mode flyback with a 40V DC output.
This stage switches at 100KHz.
Then this 40V is the input to a current mode controlled Buck converter which powers the LEDs.
This stage also switches at 100KHz.
There is no synchronisation circuitry to synchronize these two converters
I am told that i have done this wrong , and that i should not cascade two SMPS's in this way since it creates a terrible problem with electronic noise.
Is this correct ?. Will i get terrible electronic noise problems ? Also, will it be common-mode or differential-mode noise?
Hello,
