Car thermometer with voltmeter function
The main function of this device is to measure the temperature of gas installation evaporator and the engine intake air temperature.
Main assumptions:
  1. displaying 3 temperatures
  2. monitoring the voltage of car gas installation
  3. adjustable LCD backlight
  4. Small hosting
  5. Easy temperature sensor connection
Schema:
The main elements of the circuit:
  1. Atmega8
  2. Alphanumerical LCD display 2x16
  3. 3 x DS18B20 (temperature sensor)
The PCB's:
After installation:
On the picture above there are two cables:
  1. One cable to the car ignition
  2. And the second one to parallel connect temperature DS18B20 sensors
The program is written in C.
The main function what were implemented:
  • detection of number of 1 wire devices connected
  • induction and activation of one of the few 1 wire systems connected to the bus
  • temperature reading from a selected sensor
  • measurement resolution to 0.5 degrees (view to 1 degree)
  • displaying '-' for negative temperatures
  • ability to enable of disable the '-' sign
  • saving the display order form 1 wire sensors (saved in EEPROM)
  • voltage measurement to 0,1V
  • averaging rapid voltage changes (it gives a stable reference in case of small voltage fluctuations)
  • function displaying “staring voltage” - the minimal voltage during engine start
  • PWM LCD backlight control
Link to original thread - Termometr samochodowy z funkcją woltomierza
