Car fuel sender circuit calibration help
Furax
Newbie level 1
Newbie level 1
UK
Fuel sender circuit
Im having a problem fitting a set dials into a car. They are from a later model so they fit fine with the exception of the fuel sender.
The original one has a range of something like 0ohm to 450ohms, and the later a range of 50ohms to 300ohms.
Is there any easy way to build a converter circuit so the calibrations are correct.
