Aramanth
Newbie level 6
- Joined
- Nov 10, 2015
- Messages
- 11
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 94
its outputs cannot be connected to the outputs of your car radio and each of its 4 outputs have two signal wires so you will need a huge relay with 8 changeover switches, or 2 or 4 relays.
you dont want to hook that up to the speakers at the same time as the radio - it would take more parts and time then its worth and probably not sound very good
hadn't thought of that yet, thanks!But be sure to FUSE It with a 2 Amp Fuse.
thanks for thata dpdt relay per speaker
Your existing car radio might be destroyed by oscillation if your new relays disconnect the speakers from it when it is still turned on.
i see this as unlikely, though maybe i'll go back and inspect the wiring to double check, kinda thought it was only running on 4 speaker wires previouslycrossover networks that might be inside the original radio.
