Car amplifier at home (diy)
evolandlupiz
Newbie level 1
Newbie level 1
Sacramento, CA
i've got a small project going on at home for hooking up my car amplifier and subwoofers in my room. i'd like to ask for a bit of help in making sure my circuit will be okay and a bit of help in making sure i get the right power to the system. what power source in my at home area would you recommend, and can you check to see i've got the correct equipment?
for the power source i was thinking of an `adc convert 3000 watts`, thoughts?
this is what i'm using:
(1) x2 subwoofers xfire xfr 12" (*specs below)
(2) x1 amplifier 2400w memphis srx 1200d.1
(3) x1 ren20kit 4 guage
(4) x1 bass knob
(5) x1 remote switch to turn on amp
* * * SUBWOOFER SPECIFICATIONS * * *
XFR12.44 12” dual 4Ω Subwoofer
GENERAL
SIZE 12" SUBWOOFER
Voice Coil DUAL
DC Resistance (Ω) Dual 4 ohm (Ω)
Peak Power (Watts) 2250W
Continuous Power (RMS) 750W
Sensitivity 90dB
Effective Frequency Range 26Hz - 150Hz
Cone Material Kevlar Woven Reinforced
Surround Material Precision Linear Drive dual stitched resin fiber
X-MAX 33MM 1 Way
link: link to xfire item on ebay
* * * AMPLIFIER SPECIFICATIONS * * *
Mono subwoofer amplifierPeak Power 1,200 watts RMS x 1 at 1 ohm750 watts RMS x 1 at 2 ohms400 watts RMS x 1 at 4 ohmsClass D amplifier technologyVariable low-pass filter (30-250 Hz, 12 dB/octave)Selectable bass boost (0, 6, 12 dB at 45 Hz)Variable subsonic filter (15-50 Hz, 12 dB/octave)RCA and speaker-level inputsWired remote level control includedFuse rating: 40A x 34-gauge power and ground leads recommended —
wiring and hardware not included with amplifier12-9/16"W x 2"H x 8-1/8"D
link: link to memphis item on ebay
* * * AMPLIFIER KIT SPECIFICATIONS * * *
1 x 20 Apx 4ga Power Wire (red) with Flexible Strands, 5 m
1 x 20 Apx Ground Wire (grey) with Flexible Strands, 0.8 m
1 x RCA Stereo Audio Cable (blue), double shielded, 5 m
1 x 0.5mm^2 remote wire, 5m
1 x AFS fuseholder with 60A fuse
link: link to renegade item on amazon
* * * BASS KNOB SPECIFICATIONS * * *
link: bass knob on amazon
* * * REMOTE SWITCH SPECIFICATIONS * * *
link: switch on amazon
I can't help with recommendations but I'm sure glad I'm not you neighbor!
What is a "adc convert 3000 watts" and asking what is available in your home area means nothing to a World Wide forum. We have no idea which stores or suppliers are in your locality or indeed where you actually are.
Brian.
On the other forum I said that the 12" woofer has a resonant frequency too high to be a sub-woofer and the amplifier has an output of maybe 300W into each speaker's two paralleled coils.
The ebay no-name-brand speaker and amplifier junk are missing many detailed spec's which are probably exaggerated.
I agree that you need that extreme amount of power because in your car it deafened you.
