FredCailloux
Junior Member level 1
In the OrCAD CIS 16.6 database example one can find two DB fields called Allegro_PCB_Footprint and Layout_PCB_Footprint. Both fields are populated with different footprint names, and I assume, must refer to two different footprint files.
Why two different fields ?
Why OrCAD uses two different ways of representing a footprint ?
Experimentation lead me to find that my Capture CIS footprint viewer window will link to the Allegro instead of Layout footprint field.
Yet, isn't Layout an OrCAD application ?
What is the difference between the two ways of representing a footprint ?
Why is Allegro_PCB_Footprint the default footprint identifier instead of Layout_PCB_Footprint.
Basically, what is the difference between the two ?
Appreciate your help
