Power_user_EX
Newbie level 3
I in serious confusion with the caps used with voltage regulators.
Here's my doubt :
#1)
i) In one configuration for 7805 IC there is 470uF,16V Cap connected at the input side and a 47uF,6.3V Cap at the output end.
ii) In another configuration for 7805 there is a 10uF,25V at the input end while it has a 100uF,6V Cap connected at the output side.
** => My question : Whats the difference between the 2 configurations ?
#2)
According to the Fairchild semi datasheet
"(2) Cin is required if regulator is located an appreciable distance from power Supply filter.
(3) Cout improves stability and transient response. "
** => My question : So now how do i select Caps to improve stability and transient response ?
Is there any standard method ? coz the datasheet confuses me more!
Here's my doubt :
#1)
#2)
