MZaher
Newbie level 5
Hello All,
As a part of PMU chip design, I am responsible of designing capacitorless LDO which should give the supply to SRAM IP. From my understanding, designing a capacitorless LDO requires a prior knowledge of the load capacitance for proper frequency compensation and hence stability.
The issue is that SRAM IP vendor did not provide any estimations of supply capacitance. Moreover, SRAM includes multiple banks where in one extreme case only one bank is ON (32 kB) and the other extreme case, all banks are ON (2 MB). Therefore, I expect large variations in supply capacitance, is my assumption true? and if this is the case, how do you normally deal with such case?
Are there any reasonable estimations can be made about the supply capacitance from your experience that can ease up my life?
Thank you in advance!
