CapnKosmic
Newbie level 2
Hi All,
I'm trying to better understand capacitors and how they work. I know about their plate/dielectric construction. I know that they work much like batteries and store a charge. They have capacitance values measured in Farads, and are rated to withstand certain voltages. What I don't understand is how to calculate the total power a capacitor can store and what is the unit of measurement that expresses their physical size as relates to that total storage 'capacity'.
In the case of a battery, there is the unit of voltage vs. the capacity. A very small alkaline battery, for instance can have a value of 12 volts, like an A23 alarm key fob battery, but only hold a small total volume of power measured in milliamp-hours or mAh.
I've got a metal film capacitor that is about a half inch wide which has a capacitance value of 0.22 mF and is rated for 500 volts. Another one I scavenged from a microwave power supply is about 3 inches wide with the same 0.22 mF capacitance value, but rated for 1600 volts. I also know that the microwave cap has an internal resistor. How do I measure their respective abilities to store power when fully charged?
Cheers,
Cap'n Kosmic
Cheers,
Cap'n Kosmic
