beyondsense
Newbie level 1
ccfl inverter
I am buiding a DC to AC step-up inverter. And in the primary circuit, there is a plastic film capacitor (SMD) 0.022uF which fails to work under the condition of ~100 KHz, 70V.AC rms.
The capacitor spec is shown below. Can anyone advice am I using a wrong type of capacitor. Or should I use a ceramic one instead?
Thanks
Rated voltage 250 V.DC/80V.AC
Temperature range: –40°C to +125°C (with derating over 105°C)
Capacitance Tolerance: ±10% (K)
Dielectric dissipation factor: Less than 0.15 (20°C, 1KHz)
Withstanding voltage: Rated volt X 1.5 1min.
Insulation resistance: More than 15,000MΩ
Thanks
