boylesg
- Joined
- Jul 15, 2012
- Messages
- 1,023
- Helped
- 5
- Reputation
- 10
- Reaction score
- 6
- Trophy points
- 1,318
- Location
- Epping, Victoria, Australia
- Activity points
- 11,697
I have implemented this circuit on my bread board, using a KA393 comparator, and found that it behaves as a rather effective capacitive touch switch with a piece of Al tape on the back of a laminated paper sheet and a wire connecting it to Vin below.
First of all I more or less have my head around what a basic comparator does.
But I have some some questions about this more complicated circuit.
1) I am assuming that R1 and R2 form the voltage divider network as in an ordinary comparator with no hysteresis. Is this correct?
2) Hysteresis is when you feed the output voltage back into one of the inputs. So I assume that this means that the voltage on the inputs must rise above that noise level before a voltage change will appear on the output. So if you have a peak noise voltage of 5mV then voltage at the input must rise above that level before any change will appear at the output. Essentially correct? So I assume the positive feedback is happening through the voltage divider formed by R3 and R4? What is the purpose of feeding the output back into the input through a voltage divider? Why not just a wire connection?
3) What is the purpose of R5?
