Can't run Cadence Leapfrog after successful setup
aomeen
Member level 4
Member level 4
Egypt
Hello All,
I want to use leapfrog software "VHDL simulator within cadence" , I ran the setup and it quoted "setup is completed succesifully", but I cant run the tool, there are no .bin file to point to,
I believe leapfrog must be lunched as standalone "not under icfb"
Does anyone know which Env variables to define or which lines to add in .cshrc file ??
Thx in advance
leapfrog cadence
You should have a digital simulator (eg Logic Design and Verification version 5 from cadence?) if you want to run vhdl or verilog. The Cadence IC 5xx do not have digital simulator!
Re: Cadence Leapfrog
Right, But under icfb there are option to import VHDL files, from the ic manager choose File --> Import --> VHDL ,
So how come I can import a file and cant simulate it ??
This option and other (eg AMS option) are just an programming interface between Cadence IC package and other periphery softwares. So long as you have the executables and the licenses will you be able to use the option you want.
Leapfrog is not being supported by Cadence now. You can use this piece only if yo are still in IC 4xx.
    aomeen
