Can't read negative voltage values
aeytr
Newbie level 6
Newbie level 6
I built an ECG circuit that works fine. Now I want to read ECG signal via arduino analog pins(I m usingpro mini/5V/16Mhz). The problem is I cant read negative voltage values. I tried some methods but none of them worked.
Can you please help?
Thanks.
Regards.
Ali Emre
Simply apply a positive DC offset voltage to the signal so that it never goes negative unless the signal strength increases.
Simple way to lift negative voltage into the positive:
I think ECG signals need no DC measurement, therefore a capacitive coupling and biassing to ADC_VRef/2 is a solution.
Klaus
