Jerry Yau
Member level 4
java segmentation fault rhel4 solved
Hi sir,
I encounter a problem when starting ui of magma. The error messages are listed below :
mantle[1]> ui start
UI-1 Starting the Watcher process on jerry
UI-39 ERROR: Cannot Start a Watcher
CMD-56 1 ERROR message and 0 WARNING messages from "message error UI-39 ..."
CMD-56 1 ERROR message and 0 WARNING messages from "ui start"
=== PROBLEM ===
UI-39
while executing
"message error "UI-39" "Cannot Start a Watcher""
invoked from within
"if { $is_watcher_running == "" } {
return ""
invoked from within
"ui start"
mantle[2]>
How to fix the problem?
Thanks
Hi sir,
mantle[1]> ui start
=== PROBLEM ===
UI-39
while executing
invoked from within
return ""
invoked from within
"ui start"
mantle[2]>
Thanks
