Cant I connect a OpAmp directly to the Atmega?
fsoender
Member level 2
Member level 2
I got a OpAmp connected to my Atmega16. OpAmp gives me 0-3 Volts on Atmega input A/D converter.
My problem is that the value/signal on A/D input is floating. The OpAmp gives me the volt range as expected.
I have connected a LCD to see the value. When I connect power supply with
0-3 volts it works. Cant I connect a OpAmp directly to the Atmega?
Can anyone help me?
Re: Operational Amplifier
Hi Fsoender
Why not ? it should work without any problem .
Best Wishes
Goldsmith
Ok, but why is the value on my LCD fluctuating with OpAmp connected, and not with power supply with same voltage?
Can you attach your circuit here ? how i should know that what circuit you are referring to ?
Here is the circuit
What difference is your mean ? can you bring both differences here ? because apparently your circuit is correct .
Ok, good that its correct. The other way I tried is to replace the OpAmp with a potmeter, and that works well.
Here is the circuit
What opamp are you using?
What are the resistor values in the opamp's feedback loop?
What are the opamp's positive and negative supply pins connected to?
Im using a LM358, and its connected to a coil (to read magnetic field).
Resistor value 10K and 1K to get 100x
I think the LCD is not responding quick enough to see the quick change from the coil, can that be the issue?
Are you sure that it should give you 100X gain ? (1+RA/RB)=1+10000/1000=11 ! not 100 !!
Sorry I use 100K, so 101
Is there any way to "hold" the signal from the coil longer?
Here is the circuit
Output from the coil is AC (positive and negative). The ADC can not process negative voltage at it's input.
Yes.
Can't you do that in software in the microcontroller?
Yes I can do it in the microcontroller, but was wondering if there is a hardware way aswell?
I know the Coil deliver AC power, I get only positive output from the OpAmp.
