Can't find the datasheet/replacement of this IC
3Deye
Full Member level 2
Full Member level 2
EG
I am looking for the datasheet or a replacement of this IC: IL 1088EP1-03
From it's connection in the voltage regulator circuit I have, I guess it's a PWM controller. I need the datasheet to be able to find a replacement for it. Its package is 8-pin PDIP.
Thanks.
Any chance it is the part below? I dropped the IL (manufacturer) and 03 suffix
As is so often the case on old parts, they want money for the data sheet.
-Lisa
APL1088EC-PB Datasheet
Datasheet for
http://chipmanuals.com/datasheets/search/go/
Description: 500mA Low Dropout Linear Regulator
Manufacturer: Anpec Electronics Coropration
Temp. range: Min: - | Max: -
Package: Not available...
Pins: Not available...
Link: APL1088EC-PB.PDF (93 Kb)
