Cannot use 3D polar plot for monopole antenna in HFSS 9.2
ablendos
Junior Member level 3
HFSS problem!!!
Hi!
I have the problem of HFSS 9.2. I simulation a monopole antenna and get the reflection coefficient and radiation pattern. But I can not use 3D polar plot to get 3D field. I ever use smae way on dipole and it is no problem.
Do anyone help me!!
Thanks
Re: HFSS problem!!!
Check if you defined at least one radiation boundary and properly defined a Far field sphere for the far fields and also if you saved the fields forthe frequency for which you need to plot the pattern.
-svarun
    ablendos
HFSS problem!!!
I have the same problem.
So how do I define a far field sphere?
HFSS problem!!!
will some budy plz tell me how to increase the bandwidth of PIFA antenna...and example if...
thanks
