Cannot read valid data from MMA9555L
miladsh52@gmail.com
Newbie level 1
Newbie level 1
Hi everyone,
I'm working with MMA9555L module through an i2c interface, but I'm having a problem with pedometer function in MMA9555L. For a sanity check, I read back the version information which is ok and gets back the desired data but when I want to read the data from pedometer application, the slave returns 0x9C instead of 0x80 which shows the error "the command interpreter does not recognize a command code". How can I fix this error? Here is my code:
Code C - [expand]
8
9
10
11
12
void main()
   void pedometerConfigRegs();           //sets the configuration registers of the pedometer application
                                                        //send these bytes to the part: 0x15, 0x20, 0x00, 0x11, 0x00, 0x00, 0x00, 0x00,        0x00, 0x00, 0xE0, 0x00, 0xB6, 0x44, 0x04, 0x83, 0x05, 0x82, 0x00, 0x00, 0x00
   void pedometerReadValue();            //reads back from the slave
                                                        //send these bytes to the part: 0x15, 0x30, 0x00, 0x0C
   while(1)
      read_i2c(16);
Any help is highly appreciated.
Regards,
Milad.
