Cannot plot waveform while simulating in cadence virtuoso via spectre
shockingshockley
Member level 1
Member level 1
Hello!
I cant plot waveform while simulating in cadence virtuoso IC 6.1.5 via spectre.
When I initiate Netlist and Run (green button), these are the results:
Delete psf data in /home/eda/simulation/R_div/spectre/schematic/psf.
generate netlist...
Begin Incremental Netlisting Apr 6 23:23:36 2014
End netlisting Apr 6 23:23:36 2014
The netlist is up to date.
Time taken to compare the design with netlist: 0.0s
...successful.
compose simulator input file...
...successful.
start simulator if needed...
...successful.
simulate...
INFO (ADE-3071): Simulation completed successfully.
reading simulation data...
...successful.
net /in selected but not highlighted
net /out selected but not highlighted
---Any solutions? Thank you!
generate netlist...
      ...successful.
      ...successful.
      ...successful.
simulate...
      ...successful.
