swapan
Full Member level 4
Hi guys,
I am interested to make one Electronic Speed Controller to drive a small Sensorless BLDC motor. After thorough study of some application note, tutorial and article on the web, I got one code which is given as under. In the code, the variable 'j' is defined as global as well as local.In the ISR the variable 'j' is incremented in for loop and decremented in the following 'if' condition. Here I am getting confused. Please see the code and help a bit.
Sensorless brushless DC ( BLDC ) motor control with PIC16F887 microcontroller
C Code for mikroC PRO for PIC compiler
Crystal oscillator used @ 20MHz
Configuration words: CONFIG1 = 0x2CD2
CONFIG2 = 0x0700
This is a free software with NO WARRANTY.
https://simple-circuit.com/
#define PWM_MIN_DUTY 80
#define PWM_START_DUTY 200
#include <stdint.h>
void AH_BL();
void AH_CL();
void BH_CL();
void BH_AL();
void CH_AL();
void CH_BL();
void bldc_move();
uint8_t bldc_step = 0;
uint16_t motor_speed, i, j;
void Interrupt()
// BEMF debounce
int8_t j;
[COLOR="#FF0000"]for(j = 0; j < 10; j++) {
if(bldc_step & 1) {
if(!C1OUT_bit) j -= 1;
else {
if(C1OUT_bit) j -= 1;
}[/COLOR]
bldc_move();
C1ON_bit = 1; // clear the mismatch condition
C1IF_bit = 0; // Clear comparator 1 interrupt flag bit
void bldc_move() // BLDC motor commutation function
switch(bldc_step){
case 0:
AH_BL();
CM1CON0 = 0xA2; // Sense BEMF C (pin RA3 positive, RB3 negative)
break;
case 1:
AH_CL();
CM1CON0 = 0xA1; // Sense BEMF B (pin RA3 positive, RA1 negative)
break;
case 2:
BH_CL();
CM1CON0 = 0xA0; // Sense BEMF A (pin RA3 positive, RA0 negative)
break;
case 3:
BH_AL();
break;
case 4:
CH_AL();
break;
case 5:
CH_BL();
break;
bldc_step++;
if(bldc_step >= 6)
bldc_step = 0;
// set PWM1 duty cycle function
void set_pwm_duty(uint16_t pwm_duty)
CCP1CON = ((pwm_duty << 4) & 0x30) | 0x0C;
CCPR1L = pwm_duty >> 2;
// main function
void main()
ANSEL = 0x10; // configure AN4 (RA5) pin as analog
PORTD = 0;
TRISD = 0;
// ADC module configuration
ADCON0 = 0xD0; // select analog channel 4 (AN4)
ADFM_bit = 0;
INTCON = 0xC0; // enable global and peripheral interrupts
C1IF_bit = 0; // clear analog coparator interrupt flag bit
// PWM
CCP1CON = 0x0C; // configure CCP1 module as PWM with single output & clear duty cycle 2 LSBs
CCPR1L = 0; // clear duty cycle 8 MSBs
// Timer2 module configuration for PWM frequency of 19.53kHz & 10-bit resolution
TMR2IF_bit = 0; // clear Timer2 interrupt flag bit
T2CON = 0x04; // enable Timer2 module with presacler = 1
PR2 = 0xFF; // Timer2 preload value = 255
// Motor start
set_pwm_duty(PWM_START_DUTY); // Set PWM duty cycle
i = 5000;
while(i > 100)
j = i;
while(j--) ;
bldc_move();
i = i - 50;
ADON_bit = 1;
C1IE_bit = 1; // enable analog coparator interrupt
while(1)
GO_DONE_bit = 1; // start analog-to-digital conversion
delay_ms(50); // wait 50 ms
motor_speed = (ADRESH << 2) | (ADRESL >> 6); // read ADC registers
if(motor_speed < PWM_MIN_DUTY)
motor_speed = PWM_MIN_DUTY;
set_pwm_duty(motor_speed); // set PWM duty cycle
void AH_BL()
CCP1CON = 0; // PWM off
PORTD = 0x08;
PSTRCON = 0x08; // PWM output on pin P1D (RD7), others OFF
CCP1CON = 0x0C; // PWM on
void AH_CL()
PORTD = 0x04;
void BH_CL()
PORTD = 0x04;
PSTRCON = 0x04; // PWM output on pin P1C (RD6), others OFF
void BH_AL()
PORTD = 0x10;
void CH_AL()
PORTD = 0x10;
PSTRCON = 0x02; // PWM output on pin P1B (RD5), others OFF
void CH_BL()
PORTD = 0x08;
// End of code.
