Cannot generate calibreview pop-up after PEX
OrangeHalo
Junior Member level 2
Ann Arbor
Hi all,
I ran into a problem after finishing PEX in calibre. I want to generate a caliberview after PEX in order to run post-layout simulation, however, the "caliberview setting" pop-up does not appear after correctly running PEX. I wonder what`s wrong with the seetings. Here is a picture of the settings. Screen.jpg
Thanks!
Best,
Why do you need a pop up window?
If you selected Calibre View as output post-layotu netlist format, the extraction tool should just generate it. Check your directory, for the presence of this file.
Hi timof,
I mean, if I select Calibre View as output netlist format, some setup options the should appear. I attached a picture to show the pop-up.shot.jpgBut nevermind, the problem is solved by restart Virtuoso:) Thanks!
OK, thanks.
Indeed, some problems go away after you restart Virtuoso.
It's probably the first thing to try, when debugging such problems.
