mImoto
Full Member level 4
Canbus cables?
Hello,
I would like to use the canbus in a high interference environment (the board should be inside a machine that generate much EMI). So I think that I should connect the different board that comunicate by means of canbus with a shielded cable. Do you know which is the standar cables for this purpose? what are people using? connector?
Sorry for hitting you with so many questions. Thanks a lot in advance,
mimoto
Hello,
mimoto
