CANalyzer,CANoe,CANape
seshug22
Bangalore
What is the difference between CANalyzer, CANoe,CANape?
Please give me reply ASAP
Thanks
Seshu
CAPL represents the programmable portion of CANoe and CANalyzer. CANoe is built on the foundation of CANalyzer.
All the three are used for different kinds of distributed systems and under different load conditions.
CANoe possess more powerful features than canalyzer.
if you attempt to learn then first you need to learn canalyzer
Thanks Shivaram.
Then What is the difference between CANoe and CANape?
Thanks & Regards
Seshu
---------- Post added at 12:52 ---------- Previous post was at 12:46 ----------
Thanks Shivram
Please tell me what is the difference between CANoe and CANape
The use of Vector's CANoe vehicle network simulation tools provides an effective method for testing modules, and their interaction within a complex vehicle network. Using CANoe "Statemate, and Simulink models" may be interfaced with a network simulation. Network traffic is defined through the manual definition of each node on the network. The Statemate model is interfaced to the simulation and the test is performed.
CANape is a software tool from Vector Informatik. This development software, widely used by OEMs and ECU suppliers of automotive industries and is used to calibrate algorithms in ECUs at runtime.
CANalyzer - mainly used to see raw CAN frames
CANape - used for CCP(XCP) protocol, displaying variables, setting variables
CANoe - i did not work with it.
