CANalyzer and SWCAN for simulation
suryaprakash.th
I am using for CANalyzer (with CANCaseXL high Speed piggy) for SWCAN (Single wire CAN network, example GMLAN) @ 33.333 kbps.
• pin 2: CAN-Low (Ground)
• pin 3: GND (Ground)
• pin 7: CAN-High (CAN+) connected to SWCAN line to my module harness pin.
• pin 9: CAN V+ (Power)
When I communicated my node from CANalyzer - IG block, requested DIDs and wrote DIDs. Everythng is fine. All the diagnostics operations done without fail . (my module supports dignostics for SWCAN @ 33.333kbps)
The concern here is: when GMLAN (I.e. SWCAN) is into sleep, the module doesn’t gets wakeup on HVW (high Voltage wakeup event). Please provide me solution to Wakeup SWCAN/to establist communication again.
Recovery here is : recycle the power.
