Can you identify this connector please?
Git
Full Member level 4
Full Member level 4
Torino
Can anybody recognise the four 4 way connectors on this PCB please?. Even a manufacturer would be great, part numbers of male and female components would earn my undying gratitude!. The outside dimensions of the connector are approximately 15 mm by 11 mm as seen in the photo. I cannot remember the height, sorry. The through hole solder connections are unusual, in that each blade solders into four small holes in about a 2 mm square, so 16 holes in total are required for each connector. Each blade is ~2.5 mm x 0.8 mm. The blade pitch is about 0.25 inches x 0.2 inches. The PCB is made by XAG and is BLDC motor driver for a drone (usually known as an ESC). The ESC plugs into it's controller board, and the drone model is probably XP2020. Many thanks.
