Can you demodulate a FM signal using DLL?
Re: delay lock loop
you can demodulate FM modulated signal using a PLL loop
Rania
    nidahas
Re: delay lock loop
would you be having any material on how to do it??i ve searched but i cant find any.if u can please help.
thanks in advance!!
delay lock loop
Hi all,
Could you please Rania elaborate your reply by attaching a schematic showing the principle of the modulation ?
Thanks.
    nidahas
Re: delay lock loop
i have basically a narrow band fm signal.the carrier wave is of 800hz whereas the message signal is of 100hz.and i ve to demodulate it using dll.
i ve done it using pll but now i need to do it via dll.however i dont know how to proceed.
delay lock loop
the main issue about the PLL and the DLL , is the DLL change the delay , but the PLL change the phase and frequency ,
if u want the DLL to change the freququncy , u should use an delay line , and a edge combiner , in this case the DLL can change frequency , so it can be used to demodulated the FM singal ,
u need to read about how DLL can be used as Freq synthsizer , it can guide
the DLL gone need some twaeking to work as FM demodulator , good luck
khouly
    nidahas
Re: delay lock loop
umm in dll u dont ve vco.shuldnt it be VCDL.and wat is buffer amp
