CAN with PIC18F458 ? any working example?
balbes
Junior Member level 2
does anybody have working example on C ?
and another question - if the data I want to transceive is bigger than 8k, should I split it myself or the CAN controller will do it for me if I send it to him ?
Check Microchip application notes:
8kBytes? Standard defines max 8 data bytes in data message.
You have to split your data.
Check standards:
I find this on elektroda, so ...
regards
meax98
Excuse-me, if this sounds stupid. But I have one question.
What connectors are used for CAN bus and what is the pinout ?
I downloaded several docs about CAN, but there is no mention about physical layer and about connectors which are normally used for CAN bus.
Connectors and physical layer are custom :). Depends were are you
going to connect.
Typical transceivers are Philips TJA1050(newer) and PC82C250(older).
Very useful informations.
Thanks
:roll:
transceiver I use is MCP2551 ( product of microchip )
thanx for the information
