CAN with PIC Microcontroller - MCP2515 module
desgin
Full Member level 1
Full Member level 1
Hello All,
I working on CAN Project where my requirement is to give demo of CAN Protocol.
I done lots of research but no result at end :-(
I am using PIC Microcontroller for Master and Slave.
I want the system like; If i give input from Master - My slave should give me Output.
Here i am using Finger print for the authentication.
I am using MCP2515 module which has inbuilt CAN.
But i don't know how system will work ? and how i should start my coding ? Please help me out.
I am so much in worried.
Thanks in advance.
desgin
The MCP2515 uses an SPI interface to talk with the MCU.
I am a bit confused as to what you are actually trying to achieve here. Is it something like:
Master MCU <--> MCP2515 <--> (CAN protocol) <--> MCP2515 <--> Slave MCU
If so then where does the fingerprint reference come in? If the fingerprint device uses CAN then that would (presumably) replace the MCP2515 and the slave MCU i the above outline and still achieve a demo of how to write a program that talks to a CAN device.
Susan
Reactions: desgin
    desgin
Susan
Thanks for the reply.
Its actually,
[ Input of Finger Print (Module) ] --> Master MCU <--> MCP2515_1 <--> TJA1050_1 ( H & L ) <--> TJA1050_2 (H & L ) <--> MCP2515_2 <--> Slave MCU --> [ Output of Finger Print ]
I hope now you understand, what exactly i want in my project.
Thanks in Advance
Thank You
Desgin
I recommend to go step by step:
Start with the hardware: TJA1050 -- cables -- TJA1050
* first you need the knowledge about how to build the hardware. Which cables to choose, what connections are mandatory...And so on.
* then build your test circuit for this.
* use a logic signal input and a scope to check the output signal. In both directions.
Check timing, signal levels
Klaus
Reactions: desgin
    desgin
Microchip seems to offer ready-to-use MCP2515 software support only for PIC32 family. Some porting required.
Reactions: desgin
    desgin
Klaus
Ya that's fine.
I Checked SPI Protocol, it worked perfectly between 2 PIC Microcontroller because MCU_1 and MCU_2 both has to be connected with MCP2515.
MCP2515 works on SPI.
SO now my query is how can i start work with MCU_1 and (MCP2515 - TJA1050) CAN Module ?
How can i see the data on this module and so on ?
Thank you
Desgin
So you mean to say MCP2515 with TJA1050 Module will no work with PIC18 Series of MCU ?
Thanks in advance
Desgin
Ya that's fine.
This was not my recommendation.
Divide it in clear steps.
first verify proper SPI connection. Try to read some known values from the MPC2515.
If it doesn't work like expected, then
* show your code
* describe what you want to achieve
* describe what you expect
* describe what you get instead
* show scope pictures with the 4 SPI signals
Klaus
Reactions: desgin
    desgin
The first point is about understanding the MCP2515 register model, required basic setup, flow for message transmission and reception.
You can either write the PIC18 code from scratch, or try to modify existing sources, e.g. the PIC32 examples.
Reactions: desgin
    desgin
