nikhil9839859626
Newbie level 3
about dtmf
how can we make a dtmf reciever circuit using cm8870.
the transmission is through fm.
When the transmission is through FM, use a FM receiver and connect its output to the input of the 8870 decoding circuit. Construct it as per given in the datasheet. Cheersnikhil9839859626 said:how can we make a dtmf reciever circuit using cm8870. the transmission is through fm.
nandhu015 said:The Datasheet itself contains the details how to make the circuit
i cant understand the second line
i agree with you.pranam77 said:When the transmission is through FM, use a FM receiver and connect its output to the input of the 8870 decoding circuit. Construct it as per given in the datasheet. Cheersnikhil9839859626 said:how can we make a dtmf reciever circuit using cm8870. the transmission is through fm.
