Aussie Susan
Advanced Member level 5
- Joined
- Jan 5, 2015
- Messages
- 1,634
- Helped
- 415
- Reputation
- 830
- Reaction score
- 480
- Trophy points
- 1,363
- Activity points
- 19,374
I have a PIC12LF1840T39A that I want to use to generate anOOK signal in the 433.94MHz ISM band. The application schematic in the datasheet is:
This shows a crystal from the XTAL pin (pin 10) to ground in what I take is a Colpitts oscillator configuration (but I could well be wrong). The datas heet for the MCU also says that the load capacitance of the crystal should be 15pF.
The local supplier lists the following as the only SMD 24MHz 'crystal' that has 15pF load capacitance: https://www.farnell.com/datasheets/4129071.pdf. To my mind this looks more like an external oscillator (with the 'Vcc' 'Output' and 'OE' pins). [Ignore the frequency of the crystal in the schematic - that is for the 868/915MHz bands]
Can I use this "crystal" (as per the PDF) or must I look further for an actual crystal?
Susan
Susan
