moharaza
Junior Member level 3
Hi guys,
I am stuck with a problem in my research.
problem is--
as the signal passes through multiple stages the signal strength decreases.
I want a 32bit AND on single dynamic gate(for example), the signal strength starts to decrease as it passes each transistor.
what is the remedy for this...
perhaps I need a single device on that dynamic gate to amplify the wire signal strength..it cant be buffers/amplifiers as they can't be place on the single wire.
or
I was wondering...is there any FET device that will give source voltage more then the drain voltage as its characteristics?
Any sort of help/comment is most welcome
Thanks
problem is--
or
Thanks
