Can Someone, Verify mY Schematic pl ?
AjaYrUleZ
Junior Member level 2
LAX
Can Someone, Verify mY Schematic pl ? Closed of no replies
I am GLAD to receive replies...
Thank you both for your KInd Replies.....!! :smile:
So
This is regarding the below circuit/schematic of witness camera....!! I have designed in Proteus as per the circuit....Pl can some one juz verify my circuit which i have enclosed in ZIP archive as .Dsn, All is done except few flaws I would like to be pointed. I actually want the final output of the circuit to be as the attachment no 1 (PDF)
Thanks
I have attached :
1 . The Final PCB layout
2 . My design in .Dsn format
3 . Original Circuit.
  • 3.pdf
  • witnesscamera.zip
Dear Angry man!!!( according your profile picture !!!!!!)
Hi
What is your clearly problem ? the circuit that you attached is a simple circuit . is your problem with it's analysis ?
Best Wishes
Goldsmith
looks fine, keep c1 close to pin7. If you use this in a vehicle or computer power supply units, use 4700uf by the power supply, and by the fan to ground. cleans the power supply to prevent false triggers.
Waiting for ny replies pl....!! I expect a lot from EDA....
