Can someone help me in creating claps on 2 claps off without using an Arduino?
bashar_op
Newbie
Hello, I want to create a circuit that turns on with one clap but turns off with two claps without using an Arduino
I see a schematic, don´t know how much it relates to your application.
Don´t know if it is good, if you tested it ..
Please give detailled information and ask an elaborated question.
Klaus
The schematic you show has a few serious errors:
1) The yellow LED will burn out instantly because a resistor is missing to limit current from the power transistor.
2) The CD4017 IC will also instantly burn out because its +12V is connected to its carry output pin #12 instead of to its positive pin #16.
3) The ground pin #8 of the CD4017 is not connected.
4) The CD4017 will soon burn out because nothing limits the LED current since its 12V supply will be too high with no current limiting.
hello
I want someone to check my circuit to see if its works in real-life
I completed the circuit in the Proteus simulator, and it functioned, but I'm unsure if it would function in reality. I want to double-check my work. test 3 will be removed I put it only to check the circuit
please tell me what i hould do
  • project clap on clap clap off 3.1.PDF
  • project clap on clap clap off 3.1 - Proteus 8 Professional - Schematic Capture 2022-10-23 17-3...mp4
    18.1 MB
