Can someone check my LNA design?
abdoeng
Advanced Member level 2
check lna design pls?
hi all ,i prepare LNA of atf36077 at x band(8-12 ghz) with sustrate 6.15,h=25 mils
i have design it .at all i try to finish my design with s11<- 11 db,s22<-14 db,with n.f. 1.9 db and gain about 7 db any buddy agree with these data,i put t.l. of 4 mm widthat the source to connect it to holes i use 4 holes.is that right.
regards
i use ads2003
regards
Re: check lna design pls?
i think it is ok , but the gain is low , it will very good if u increased it
khouly
hi kouly,i i increase it,the s par.will be more worth.
