can somebody help me understand this piece of code of an FIR
superhet
Junior Member level 3
module fir_srg (clk, x, y);  //----> Interface
  input        clk;
  input  [3:0] x;
  output [3:0] y;
  reg    [3:0] y;
// Tapped delay line array of bytes
  reg    [3:0] tap0, tap1, tap2, tap3;
// For bit access use single vectors in Verilog
  always @(posedge clk)  //----> Behavioral Style
  begin : p1
   // Compute output y with the filter coefficients weight.
   // The coefficients are [-1  3.75  3.75  -1].
   // Multiplication and division for Altera MaxPlusII can
   // be done in Verilog with sign extensions and shifts!
    y <= (tap1<<1) + tap1 + {tap1[3],tap1[3:1]}
         + {tap1[3],tap1[3],tap1[3:2]} + (tap2<<1) + tap2
         + {tap2[3],tap2[3:1]}
         + {tap2[3],tap2[3],tap2[3:2]} - tap3 - tap0;
    tap3 <= tap2;  // Tapped delay line: shift one
    tap2 <= tap1;
    tap1 <= tap0;
    tap0 <= x;   // Input in register 0
  end
endmodule
this is basically a 4 tap FIR filter. it was taken from the book "Digital Signal Processing with Field Programmable Gate Arrays" by Uwe Meyer.
the difficulty that i am having in understanding this code is in the always block. i understand the non-blocking assignments tap3 <= tap2 etc but i dont understand how y is calculated.
please help
Re: can somebody help me understand this piece of code of an
4 tap filter eqn for ur design is:
y = (-1 * Tap0) + (3.75 * Tap1) + (3.75 * Tap2) + (-1 * Tap3)
while Rearranging it looks like:
y = [(2 + 1 + 0.5 + 0.25) * Tap1] +
[(2 + 1 + 0.5 + 0.25) * Tap2] +
- Tap3 +
-Tap0;
Now Correlate this with ur verilog code:
y <= (tap1<<1) + tap1 + {tap1[3],tap1[3:1]} + {tap1[3],tap1[3],tap1[3:2]} +
(tap2<<1) + tap2 + {tap2[3],tap2[3:1]} + {tap2[3],tap2[3],tap2[3:2]} +
- tap3
- tap0;
tap <<1 means -- shift left, which is as good as Xly by 2.
{tap1[3],tap1[3:1]} -- means shift right with msb intact-- as good as xly by 0.5
{tap1[3],tap1[3],tap1[3:2]} --means shift right by 2 -- as good as xly by 0.25
So adding all these u get 3.75 * Tap1
Similarly for the Tap2 also
Hope this helps
    superhet
Renjith you are my hero.
now it becomes all clear to me. actually i didnt see this type of bit shifting before. i knew that it was concatenating bits but i didnt know that it was actually shifting the bits.
Added after 1 hours 39 minutes:
in all the excitement i forgot to ask one thing. cant the >> operator be used for shift right? whats the difference between using the >> operator and using concatenation as in the code?
