Can some suggest good slic ICs ?
sullybully
Junior Member level 1
Mars
I'm guessing you're looking at a short loop application ( < 2Kft ). I'm currently using the Silicon Labs Si3210 SLIC. https://www.silabs.com. It has a built in controller for a DC-DC converter to generate the ringing voltage. I also noticed you asked about DTMF decoders in another post, the Si3210 has DTMF detection built-in. It also has a couple of oscillators you can use to generate dial tone and stuff.. Cost about $9 in low qty.
Thankyou very much.
Is mt8880 is obsolete ?
Infineon also makes this type of products with codecs and dsp's on them.
Try their site, it can be a good source of information. We have been using their slic's for a long time with no problem.
Hi all
Does any one have ebook or papers on the design of digital switches and the used protocols.
Thx in adavance
Re: SLICs
see silver slic
Re: SLICs
Hi sullybully,
the MT8880C Integrated DTMF Transceiver is not obsolete ;
you can get it from zarink site
h**p://products.zarlink.com/product_profiles/MT8880C.htm
Re: SLICs
Holtek also make a range of DTMF genrators and receivers. Check out https://www.holtek.com.tw
They also make some interesting telphone products.
