can PWM module used here control the position in servo motor
PIC servo
Newbie level 1
Newbie level 1
servo
im a newbie in learning microcontroller... need a lot of help from u all... i have a PIC16F877A... and some RC servo motor.... can PWM module used in here to control the position in servo motor??? or need to use timer0 interrupt?? which method better?? in C language... im using Micro C compiler...
if i wanna control multiple servo motor such as in hexapod... which kind of microcontroller(MICROCHIP PIC) is the most suitable???
if can... can anyone supply me a sample coding of controlling servo motor using C language? really need help from u all... thanks...
servo
Use pic24 microcontrollers, medium scale that suit your needs.
But in general culture...
First evaluate your project, against:
inputs,
outputs,
RAM,
ROM (Flash)
embedded modules (Microcontroller Hardware like UART)
Then select a microcontroller that suits your needs.
Finally look some modules (or daughter boards) of communication (wireless or not).
