lkminz
Member level 4
Hi There,
in order to increase antenna gain, meta-material lens is getting popular these days.
I wonder, if we consider size and possible gain of the antenna (limited to size -see the formula in attachment)
- then for a fix size is it possible to increase antenna gain using meta-material lens?
when we apply meta-material lens the overall size of the antenna increase. will it be possible to develop antenna (without meta lens) of bigger size to get similar gain as with using antenna with meta lens?
kindly scholars having experience with meta-material antenna help to get some insight into the size vs gain of antenna using meta-material.
Thanks
Thanks
