can linux os ported into arm lpc2129 ?
rangerskm
Full Member level 4
Full Member level 4
i need to port linux os in to lpc2129..
what all the things i should be aware of os porting ??
Normally,linux need MMU support.If lpc2129 ARM process do not has MMU inbuilt,you can not do that.otherwise uclinux is your best choice.
thanks a lot,,
what all the requirement to port uclinux ??
