Can I write a code/program in a flash memory of a uP/ARM using LAN connection?
caif
hello to everyone ,
I'm curios if anyone knows if it's possible to write the code/program in a flash memory of a uP/ARM using LAN- connection. Can I have the possibility to program or change the code using ethernet connection in LAN? :shock::roll:
Yes you can. Depending on the moment you want write to flash memory it exists two ways. At boottime google "ethernet bootloader arm" or when application is already running google "ethernet iap arm".
Gomez
