saulbit
Member level 4
I am dealing with a troublesome circuit. The first IF is 5.4GHz, and the bandwidth of the first IF filter is about 100MHz. What is more, the second IF is about 300MHz, so I have to rejecte the possible (5.4GHz-2*300MHz) outputs of the first mixer (The first LO is higher than first IF). I have to choose a bandpass filter, with center frequency of 5.4GHz. The parastic band of such filter is a bit severe in 9GHz. So I want to use a LFCN-5500+, which is a lowpass filter and could offer about 30dB rejection in 9GHz, direct cascade with the bandpass filte ? Can I just do it? I can't find the answer in many books.
By the way, since the passband of the LFCN-5500+ is beyond 5.4GHz, so the impedance of bandpass filter in 5.4GHz band is not influenced by the LFCN-5500+. I mean in direct band, not for the case of insertion of an amp.
Here is the datasheet of the LFCN-5500+.
